How can a robot be mounted from the ceiling?
  • robotik
  • February 23, 2020 at 9:19 AM
  • robotik
    43
    Please write down your experiences
    Edited 4 times, last by robotik (February 23, 2020 at 2:42 PM).
  • robotik February 23, 2020 at 2:09 PM
    Changed the title of the thread from “How can a robot be hung from the ceiling?” to “How can a robot be mounted from the ceiling?”.
  • Boring_robot_guy
    36
    • February 24, 2020 at 4:10 AM
    Depends on a few things. Physically mounting it is no big deal (assuming the robot is designed to be inverted), and changing the appropriate parameters is no big deal either. The messy part can be with FSU and certain option combinations.
    Can you give any more details about the system?
  • Robodoc
    56
    7
    1,062
    • February 29, 2020 at 3:08 PM
    Make sure your structure can hold the mass of the robot and the inertia of the arm.
    Don't mount a 50 KG or higher.
    Make and use user frames.
    Be sure to have enough room behind the 1BC,2BC plate to remove the harness with the robot upside down.
    Call Yaskawa to confirm the arm you are using CAN be inverted and if there are any settings you can use to help.
    Robodoc
  • hung
  • ceiling
