I am not getting WFS in first column - getting AMPS in place of it
Also why am i not getting trim option???? I am getting Voltage in second column
which variables control this specifically ?
I think you need to change the Weld Procedure. Different procedures and different equipment gives different data.
Your welding powersource is probably set to short circuit welding. You need to go to the menu on the powersource and pick a pulse procedure.
Make sure your wire diameter and gas mix ratio are correct for what you are using.
My weld procedure is set as No#18 -RapidX ArCo2 , GMAW-P
Still not getting WFS or Trim
Which controller and power source are you using? Was the powersource being changed cause this issue?
R450 Lincoln power source
Refer this , courtesy diy robotics forum
