I have an R2000iA/165F with a 12HP spindle that I currently use in production for trimming and drilling fiberglass. I'm wondering about giving it a secondary use machining shapes out of foam for our mold shop. Right now the mold shop guys use a completely manual process involving gallons of bondo and lots of sanding so any sort of automation will be an improvement in accuracy as well as tremendous labor savings. I know there is CAM software for machining with robots (roboDK, Octopuz, etc) out there - any advice and/or recommendations would be appreciated.
Machining with R2000iA?
- TitusLepic
- Thread is Unresolved
What are your accuracy requirements?
+/-1/8"
Can this be accomplished with 3axis machining or does it need to be 5?
It would have to be 5 if I were to use a CNC
Hi TitusLepic,
I am in the same boat. The other day I was wondering what could be the secondary uses of the robot. Being able to carve foam out for the mold shop would be very cool. Did you ever find the appropriate Cam program for it?
Best,
Frank
Sadly, this project fell off the radar about 2 years ago and I haven't thought about it since. Sorry.
TitusLepic Thank you for the reply. I completely understand. It is one of those nice to have but non-urgent projects.
I've used fusion 360 for robot plasma cutting, albeit in a 3 axis manner. Had to write a custom post processor, but I don't think it would be too difficult to expand it to 6 axis.
Downside is that the post doesn't know where the robot is, so reachablity checks were not done.
