learning how to use Ethernet ip
  • ShangriLa
  • February 7, 2020 at 5:36 PM
  • ShangriLa
    I've been working with r-j3ib controllers using the RO/RI to communicate with a siemens plc, but now the company just bought 5 new robots with a r-30ia controllers, now as I think that there is no robot input/output I need to learn how to use it with a Ethernet ip, I just saw a video where you need to go to menu>I/O>Ethernet ip but this doesn’t appear on the teach pendant
    is it disabled?
    Do I need to change a variable?
  • stare284
    24
    373
    • February 7, 2020 at 6:06 PM
    You have to purchase the Ethernet Ip scanner or adapter option
  • kwakisaki
    694
    4,770
    • February 7, 2020 at 6:40 PM
    If you have/can obtain Roboguide, then you could use this to learn about Ethernet/IP.
    You can add the above options that stare284 mentioned in Roboguide in order to evaluate them.
    Therefore Roboguide is a great tool for learning about all of these options before committing to purchasing them on a real world robot in addition to this, Roboguide has the ability of connecting to a real world ethernet/ip device via your PC LAN connection so you could literally teach yourself how to configure it and test it and then feel confident in applying/integrating it to your live system.
    Certainly worth considering.
    The following thread discussed using Roboguide to connect to a real world ethernet/ip peripheral.
    Roboguide to AB PLC?
    I put a small video in there of the results (This how I learned about ethernet/ip with Fanuc).
  • saberlars
    Robot, beyond Human..
    22
    231
    • February 10, 2020 at 9:37 AM
    I can Describe only "Adapter" Type.
    Robot Controller : Adapter
    Master PLC : Scanner
    1. Setup I/O Range.
    - Press I/O Button and Assign I/O Range.
    - Out / In both need setup.
    - RACK 89 is "EtherNet/IP" device meaning.
    - SLOT 1 is Main_Board's RJ45 Port.
    (Almost contain 2 ports. EtherNet/IP communication recommend Upper Port.)
    - Include UOP Area, DO Range "START" from value 21.
    - Include UOP Area, DI Range "START" from value 19.
    - Without UOP Control by Master PLC, "START"from value 1. (when other field-bus control UOP Signal)
    2. Setup Controller IP Address
    - "IP Address" must given from Scanner (Ask PLC engineer)
    - "Subnet Mask" is 255.255.255.0 default. do not modify.
    - "Board Address" is showing MAC addres. do not modify.
    ABB, FANUC, Hyundai, Kawasaki
    Edited once, last by saberlars (February 10, 2020 at 9:56 AM).
  • saberlars
    22
    231
    • February 10, 2020 at 9:52 AM
    3. Setup EtherNet/IP Type, Enable, Status
    (below explain only for Slot 1)
    - Slot number is as same "I/O" config Slot
    - Description : You can remark favorite name.
    - TYP : Adapter
    - Enable : False (after all setup done, must be change to TRUE)
    - Status and Slot : Do not modify
    - and, move cursor Slot 1 line and Press F2 [CONFIG]
    4. Setup EtherNet/IP Data size
    (when, adapter config("Read-Only") showing, you have to ENABLE's parameter set "FALSE" value. Read_Only unable to modify below In/Out words size.
    - Description : as same before EtherNet/IP List
    - Input size (words) : 8 words = 128bits (Di 001 ~ Di 128)
    - Output size (words) : 8 words = 128bits (Do 001 ~ Do 128)
    - Alarm Sevarity : Do not modify
    - Scanner IP : after "ENABLE" parameter turn to "TRUE", that from will be showing Scanner (PLC) IP address.
    API O =>T : Automatically showing value.
    API T=>O : Automatically showing value.
    5. Rs_Logix Assembly Instance
    Input Assembly Instance : 101
    output Assembly Instance : 151
    This value needs for PLC parameter.
    6. Robot Cold Start
    7. EtherNet/IP Connection set "TRUE"
    - Reference Chapter 3 "ENABLE"
  • saberlars
    22
    231
    • February 11, 2020 at 4:30 PM
    Sorry. One thing missing.
    8. This data sheet for Registration Robot Field_bus to PLC
    - PLC must assign which device connected thru ehternet cable.
    - this sheet describe Electronic Data. (EDS)
Similar Threads
  • Dynamic control of FANUC Robot in Run-Time
    • Gokul N A
    • July 3, 2019 at 10:39 AM
    • Fanuc Robot Forum
  • Setting up Profisafe KRC4 Siemens S7-1500
    • Carleton Hall
    • January 23, 2020 at 6:30 PM
    • KUKA Robot Forum
  • New to Kawasaki robots help with Software
    • ericwiz7923
    • November 12, 2019 at 2:12 PM
    • Kawasaki Robot Forum
  • New in the field
    • Nunubot
    • May 11, 2018 at 12:30 PM
    • General Discussion of Industrial Robots Only
  • Newbie questions about becoming an integrator, how to get into robotics field.
    • Tjarkur
    • January 4, 2018 at 2:17 AM
  • Kawasaki FS20N with a SCADA system.
    • gustavotl
    • March 9, 2016 at 4:44 AM
  • Kuka and Devicenet
    • dimspa
    • March 6, 2016 at 9:20 AM
    • KUKA Robot Forum
  • R30iA - 2000iB pedestial
