I am seeking information on a system variable in a Fanuc robot that changes state when a USB device is plugged in or unplugged. I'm aiming to use these events to trigger BG logic when a device is plugged in.
Edit: Going by other robots I have used that are done in PDL, I believe the system variable I need would tie into the EVENT command (in Comau Robots, plugging a USB into the cabinet USB port triggers Event 155, where unplugging it triggers event 156).
~Luke S.
