Code
hello i have a problem with motoman nx100. namely, the axes fell and I set the zero point again. I set the program, everything, okay, there is only one problem, the table does not want to rotate on the master, it is on "WAIT SOUT # (56) = ON" is in the working mode and nothing happens. I will add that if I set it to the next point, the table will move normally.
