Motoman nx100
  • Code
    hello i have a problem with motoman nx100. namely, the axes fell and I set the zero point again. I set the program, everything, okay, there is only one problem, the table does not want to rotate on the master, it is on "WAIT SOUT # (56) = ON" is in the working mode and nothing happens. I will add that if I set it to the next point, the table will move normally.
  • SOUT#(56) is OT Release. This bit turns on when you go to ROBOT, OVERRUN& S-SENSOR and press RELEASE. As soon as you exit that screen the bit turns off.
    This process is for recovery of the robot when either:
    The overtravel limit switch on the S-axis (could be others) has been tripped.
    or
    if a shock sensor is installed between the T-axis flange and the tooling and has been tripped.
    Has this been running before with that line of instruction in it?
    Is there a possibility that the job has been changed to where that line of instruction should be WAIT SOUT#(57)=ON? SOUT#(57) is cube or axis interference #1. That would make a lot more sense that the table should not rotate unless the robot was in a known position. The I/O in the job lines up with a older sweep/rotate job.
