Hello everybody,
I use a KRC4 KR120R3200PA robot to forming a layer of sack. The version of the robot is KSS 8.3, on which it is installed Conveyortech 6.0.1.
Everything is working properly. The problem is that due to the wrong position of the robot, the line is slow, because I have to use linear motions to forming sack and not ptp.
How could linear motion be approximated to ptp speed?
This version of Conveyortech does not allow the use of SLIN movments. Occasionally to me now when I turn the sack for a 180 °, it already tells an error: command velocity exceeded A6. I really corrected the error by giving $vel.ori1 and $vel.ori2 from 300 to 150.
Does anyone have any solution?
Thank you for your help.
