kuka lbr iiwa TCP modification inside application
  • Hello,
    With the help of a vision system, i can get the difference in position of the tool, relative to a master position.
    Using those delta values: deltaX, deltaY and rZ, i want to then adjust the TCP.
    How can i modify a predifined tool inside the application?
  • This could be what you need, I haven't tested but seems it should work.
    // define(or inject) your tool first.
    // attach your tool to the flange
    ObjectFrame newTCP = tool.addChildFrame( "newTCP", Transformation.ofTranslation( x, y, z ) );
    tool.removeFrame( newTCP );    // if the first line actually creates "newTCP" under your Tool in ObjectTemplates. You might need to delete it on dispose.
