PNS execution
  • brian.b
  • January 13, 2020 at 1:32 PM
  • brian.b
    7
    49
    R30iB+, two MH and one weld robot. All robots are having the same issue...
    I'm to the point where I'm integrating a cell and checking functions from the HMI. When I try to send the robot home or to a repair position, via PNS, the HMI/PLC properly calls up the correct PNS program and executes it. Once the program is complete in the robot program, the cursor returns to the top of the PNS program and it restarts the program that just completed for a second or two and then aborts out of it on its own.
    The only thing I know or can tell is that the program is not written to repeat itself and that when the program has completed, I can see that UO3 (Prg Running) and UO10 (Busy) turn off, the cursor returns to the top, and then the program runs again for a brief time before aborting out.
    Any thoughts? Is this a PLC/Controller processing issue?
    Any help would be greatly appreciated!
  • HawkME
    568
    10
    3,268
    • January 13, 2020 at 7:10 PM
    • Best Answer
    Sounds to me like a PLC issue.
    Check UI[6] and UI[18]. The correct PLC programming routine should pulse on UI[18] briefly and then it should remain off until the next cycle is needed. UI[6] should not be used unless there is some kind of pause/resume logic required.
  • brian.b
    7
    49
    • January 13, 2020 at 9:54 PM
    So your feedback got us back on track. From what I was told, the PLC was trying to command the program start bit at two different points during program execution for whatever reason. Since we reference past jobs, most likely, this was a timing issue or a band-aid that got implemented on a previous job that didn't work on this project.
    Thanks!
Similar Threads
  • CNT not working with PRs
    • vmec
    • September 18, 2018 at 12:49 AM
    • Fanuc Robot Forum
  • Exporting execution history?
    • TitusLepic
    • May 21, 2019 at 11:32 PM
    • Fanuc Robot Forum
  • macro execution
    • KalebM
    • December 13, 2019 at 7:49 PM
    • Fanuc Robot Forum
  • Variable to adjust program pointer lookahead?
    • romanzo
    • November 10, 2019 at 10:00 PM
    • Fanuc Robot Forum
  • path change backwards execution required
    • Joshua460
    • September 17, 2019 at 4:07 PM
    • Fanuc Robot Forum
  • Continuous move triggering IO early
    • JMan1
    • June 5, 2018 at 7:00 PM
    • Fanuc Robot Forum
  • Clearing an Argument Register ar[#]?
    • dustinmeckley
    • June 13, 2017 at 4:55 PM
    • Fanuc Robot Forum
  • Controlling execution timing
    • Jaycephus
    • February 25, 2017 at 12:32 AM
    • Fanuc Robot Forum
  • Prexe Variables
    • toso
    • October 6, 2016 at 1:00 PM
    • Fanuc Robot Forum
  • Difference between CALL_PROG, RUN_TASK;CONTINUE,CONT_TASK; PAUSE, PAUSE_TASK
    • Rick_
    • May 25, 2016 at 11:06 AM
    • Fanuc Robot Forum
