Hi all
Im getting to grips with my krc2 kr210 robot which I use for milling. I want to check a few things and see if I can improve its performance.
Firstly I've searched Google and cant seem to find the answers so all help here is greatly appreciated.
I run a 3d scanning and measurement company so have the use of our creaform metrascan for measurement and tracking. I would like to use this tool to accurately map out the arm lengths and axis centres of all the joints and compare this to the values set on the krc2 controller. First questions is therefore where's do I find these values on the controller? And what reference are they in? Ie is the centre of the rotational plane of A1 0,0,0 ? And what format are the values, cartesian or other....
Next up is , I can measure the weight of the spindle and also determine the cog through scanning the spindle. This is done by scanning the spindle hanging on a rod . Yhe rod naturally hangs vertically and passes through the CoG. By doing this 3 or more times with the spindles weight hanging on the rod in different positions it defines the CoG by the intersecting point of these rod axis.
I can therefore very accurately map out the joint positions and pay load CoG to approx 10 microns.
And my hope is inputting these values into the controller, improves the robots performance and accuracy.
Cheers
Doug
