Hi all!
* KRC2 + windows 95.
I've always worked with only one fieldbus in the same robot cell, this means I've always had to worry about the number of input or output to declare a signal variable:
SIGNAL myDeviceNetInput $IN[1]
SIGNAL myDeviceNetOutput $OUT[1]
That easily identifies that both variables are the first input and output respectively...
But how should I declare a signal in another fieldbus given there are 2 fieldbus interfaces in the same cell?
SIGNAL myProfibusInput $IN[1]
SIGNAL myProfibusOutput $OUT[1]
The proghbexpert_r5 2_en manual doesn't explain this...
Maybe... is that in the iosys.ini? should I declare the IN and OUT ranges there?
Thank you all!
