Hello!
Does anyone have a guide on how to use dosbox with kfloppy? I need to create a backup.
Hello!
Does your controller have the slot for 32 pin card adapter?
It has the RS232 connector. I have a cable and an adapter for it.
if you google RS232 port, you will see an adapter that A flash drive card will fit into.
You can use this to make your backup onto the flash drive. any card reader that will accept A flash drive card will let you load A back up to your computer.
You can searce memory backup on this forum for more details on the steps required on the teach pendant.
I use it like this and works fine for me:
-in usb settings set com1 for your adapter
-open dosbox and type:
-serial1=directserial realport:com1
-mount c c:\kfloppy (name of the folder where kfloppy is stored on your pc)
-c:
-kfloppy.exe
-in kfloppy settings set port number com1
