We are experimenting with setting up passwords and just learning how to do it. Is there a way to export the XML file from WeldPRO to my computer to be able to edit it?
With the password system, you cannot export a password xml until you have imported one. Once you have imported one, you can export to a USB drive (or presumably to any other location). Best to put an empty xml file names password_export.xml on the flash drive before you plug it in, as i believe it can only overwrite an existing file with the export.
