Hello How can I change with Kuka 5.6 software so that you do not deactivate the Admotor mode automatically departs to the user mode and I have each of which to send it in a manner as to deactivate only when you spend little time, there is some way. Thank you.
Disable Kuka software password or change the time it is deactivated.
Francisco -
December 17, 2019 at 3:27 PM -
please use Google Translate to verify your content before posting. this is unreadable.
automatic logout can be controlled by settings in Authentication.config which is in
C:\KRC\HMI\Config (before KRC4)
C:\KRC\HMI\SmartHMI (KRC4)
Hi I have a KRC2 would it be the same method? ..
Thank you.
yes
just the path to file is slightly different
in fact screenshot i marked is Authentication.config from KSS5.x
I will try it and tell you something.
Thank you very much.
you are welcome and - make sure to make backup before you change anything....
Ok, thanks in the forum Kuka refers ..
When it refers to backup it refers to that particular file in case it fails or to the complete disk.
Thank you
it is a good idea to backup at least that file if that is all you are going to change.
the older the system, the more likely is that HDD will fail. so it is a good idea to make different forms of backup while things are running.
please read pinned topic READ FIRST and resample those attachments. don't be a litter bug
Thank you, so I will do and test first on a copy of the disk how it goes.
Thank you very much it worked for us first.
Merry Christmas..
