I've been fighting with setting up DeviceNet for a while now, trying to either figure it out or learn what questions to ask using the other threads around here.
I have a KRC2 Ed05 KR210-2.
It's got an LPDN scanner, an A30 multi-power tap, and a Turck FDN20-16xsg IO station, set to Mac ID 2.
I have an MFC and don't have a preference of LPDN vs MFC, I just need to switch solenoids for the most part - I'm pursuing the LPDN for now because I've read it's got more capability... for the future.
I wired according to post #11 on Devicenet problems (although my cable goes through the A30 power tap, maybe I should have skipped it)
The cable runs from the Turck unit to the tap, then out to LPDN Ch1 (X801 is an old sticker) with 121ohm resistors on the extreme ends. Resistance between is 60ohm, but I don't have the shielding grounded, I'll do that in a bit.
The #2 LED light on the the LPDN card is flashing red, #1 is off.
Here are my current configurations:
DNSC_1CO:
[CONFIG]
MAC_ID=2
BAUDRATE=500
DEBUG=1
DNSC_1SL:
[2] <<This must be 2 to boot error-free
MAC_ID=2
VENDOR_ID=256
PRODUCT_TYP=7
PRODUCT_CODE=2801
POLL_RESPL=3
POLL_CMDL=2
IOSYS.INI:
[DRIVERS]
DNSC1=12,dnsc1Init,dnsc1drv.o
[DNSC1]
;INB0=2,0,x1 ;$IN[1-16] <<< No matter what I've tried here, I get an IO Configuration Error. I don't want to waste time here if my problems are further back, so i commented it out.
The DNSC1 error log states "No slaves in scanlist-file" and shows ERROR [2]: No device
My Turck device should be slave #2, shouldn't it? Should it be listed in both CO and SL files?
I haven't been able to get Telnetk to do anything.
