Hi
I have a robot KRC4 at hand. It moves in T1 mode, but I can't move it in auto mode. How can I do that?
How does kuka krc4 work in automatic mode?
- PARLU
- Thread is Unresolved
complete safety circuit, step out of cell, acknowledge operator safety to confirm that nobody is in harms way.
this will allow you to manually enable drives.
Press Start Key on the SmartPad.
how to safety circuit?
i will try tomorrow...
I hope the problem is solved....
thanks you for your time panic mode -
I thought
Is this problem related to x11?
don't understand in previous posts came confused?
Do you need software from the laptop to work in automatic mode?
yes, this is related to safety circuit of the robot as both of my replies indicated. whether or not that is X11 or some network based safety option, depends on your exact configuration. either way, you still need to be qualified to operate robot. if you don't know how to use it, you should not use it.
Hi
I have a robot KRC4 at hand. It moves in T1 mode, but I can't move it in auto mode. How can I do that?Read the manual.
No, seriously. Ask a vague question, get a vague answer.
For instance, you provided NO DETAILS about your robot's safety configuration, what error messages the pendant shows when you try to use auto mode, or even which "auto" mode you are using -- AUT or EXT. If you aren't going to make the effort to provide the details that we have to have in order to offer you any meaningful help, why should anyone make the effort to help you?
