Backup and Backdate.dt via FTP on Fanuc Robot
  • LCotta
  • December 10, 2019 at 10:38 AM
  • LCotta
    I have an issue regarding with making backups on fanuc robots via ftp. I made an script on my own to execute on command window on Win systems which works fine, and I also try the ERBU utility, but I find that I cannot get the backdate.dt file. My question is if there is a way to save/get this file via ftp. Any help would be appreciated.
    Thank you very much in advance.
  • HawkME
    570
    3,270
    • December 10, 2019 at 12:30 PM
    If you get all the files it should be there. Can you show the lines of your script code that handles the get.
  • LCotta
    • December 10, 2019 at 12:43 PM
    The problem is that on RJ3 old controllers I can´t get the backdate file from ftp. When I make a backup to MC (PCMCIA), I have all files. On new FANUC I don´t have this problem.
    The lines on my script are the following:
    echo mget md:*.*>> temp.txt
    rem echo mget md:*.ls>> temp.txt
    rem echo mget mdb:*.*>> temp.txt
    rem echo mget md:posreg.va>> temp.txt
    Thank you in advance.
  • Gunjan Trivedi
    36
    • December 10, 2019 at 1:10 PM
    ftp> ls , when you hit enter . You will see all the list of files .ls , .tp , .va , .vc and many more.
    do you see your file there ?
  • HawkME
    570
    3,270
    • December 10, 2019 at 1:53 PM
    Try it without the "md"
    echo mget *.*>> temp.txt
  • LCotta
    • December 11, 2019 at 9:52 AM
    Quote from Gunjan Trivedi
    Hi Gunjan, thanks for your answer,
    When I do ftp>ls, Backdate isn´t present, but only on some old RJ3...
Similar Threads
  • Renault FANUC standard (Alliaz / Alliance)
    • massula
    • May 24, 2018 at 9:52 PM
    • Fanuc Robot Forum
