Hello
I am currently working on a Fanuc R2000ib/150U with R30iA Controller.
This robot is hanging upside down on a 7th axis rail unit, the axis is setup in group 1 as axis 7.
Question 1:
The mastering for this robot is incorrect, because the master counts don't match the factory ones. I read on this forum that the vision master option is good way to remaster the robot accurately, but that it only masters axis 2, 3 , 4, and 5. and that axis 1 and 6 are "close enough" with just an eyeball zero witness mastering. assuming this is the case, my axis 1 witness marks are scraped off so I have no way to align it. Does anyone have any way to zero axis 1 accurately without the witness marks?
Question 2:
This is my first robot with an extended axis. This robot has irvision. I'm curious how the 7th axis will effect the vision calibration. lets imagine the robot is mounted just a hair off parallel on the rail; unit, which would magnify the error as the robot moves along the rail. how do I deal with this? I assume the same thing applies with user frames? so will I need to always be in the same position on the 7th axis when using irvision or am I overthinking this and it won't be a problem?
thanks in advance
