HandlingPro import backup
  • Hi,
    my name is Arcadi and I'm new in Fanuc Robotics world. So, I would like to study all of this subject using the HandlingPro simulation.
    I have a backup of a real situation, and I would like to execute the process, but I have the next errors (I've attached a photo).
    * SRVO-409 DCS SSO Servo Disconect
    * SRVO-408 DCS SSO Ext Emergency Stop
    * SRVO-407 DCS SSO Fence Open
    * SRVO-406 DCS SSO SVOFF input
    Do you know how to disable these errors?
    Thanks :smiling_face:
  • DCS is complaining because it is not getting those signals from a safety PLC.
    You will have to disable DCS, or disable the SAFEIO mapping in the DCS menu that is driving those faults.
    In SAFEIO it would be a CSI bit, but which one depends on how it is mapped. The CSI bit would be mapped to a SSO bit, so look for what is driving those.
    Thanks Nation.
    How can I disable the SAFEIO mapping? Which menu can I find this request?
  • Hi everybody,
    I've find where is:
    * In the workspace menu, at left screen
    * open Robot Controllers with +
    * open Robot Controller1 with +
    * Double click at the robot
    * In the new menu, click on the button "Serialize Robot"
    * In the new menu, select "6.Robot Options"
    * Search DCS and descelect all the options
    * Next
    * Next
    * Finish
  • While that works... It is like having a hangnail, and solving the problem by cutting the finger off. I like keeping DCS enabled, but safety comms disabled, so I can verify paths against existing DCS zones.
    How do you disbale "safety comms" in Roboguide Simulation.
    Thank you
