Need Help with an EA1400N with a slipping T-axis
The problem we are having with one of our Arc-world 6200. NX100 with two EA1400N Robots. One of the robots keeps losing its tool center point. It appears only with the T-axis. It does not trip the shock sensor, but the operator notices to weld locations are off and will stop to correct the TCP. Every time we check TCP the T-axis has moved up to ½” only in the (T) joint rotation. We can correct it by manually turning the T-Joint axis by hand with or without the servo power on. We have checked the Motor and belt for movement or slippage, but all appears normal. Have you seen this before? Do you know of anything to check, inspect, and or tighten to correct this problem.
