  4. Comau Robots
C4G How to edit data from file.c4g
  • Mateusz.MK
  • December 9, 2019 at 10:40 AM
  • Mateusz.MK
    7
    I need change home position in robot c4g, position data home pos is save in c4g file. But I can't save file , translate pdl to c4g... WinC4g does not allow writing this file.
    How edit data in this file?
  • massula
    205
    8
    1,439
    • December 9, 2019 at 11:10 AM
    Are You writing new home position values on .pdl file, and trying to convert it to .c4g file?
    Or are You writing the values on .c4g file and can't save it?
    What is the version of Your WinC4G?
    Are You using the corresponding lib version when trying to save/convert?
  • Mateusz.MK
    7
    • December 9, 2019 at 12:14 PM
    Yes, I was try it. When I edit pdl file and click translate generate only code file without c4g file.
    Version WinC4G 3.34
  • massula
    205
    8
    1,439
    • December 9, 2019 at 12:17 PM
    Do You have the original .c4g file?
  • Mateusz.MK
    7
    • December 9, 2019 at 12:27 PM
    Yes, the same situation is when I save configuration c4g on setup page in TP.
  • massula
    205
    8
    1,439
    • December 9, 2019 at 12:28 PM
    So, I've found an old C4G backup here, and made some tests.
    I'm using WinC4G 3.22, and the robot software is 3.03
    I pick the .c4g file, converted it to PDL, edited home values, and translated it again.
    The translates file wasn't a c4g file, but a .cod file.
    But I believe if You change the extension from .cod to .c4g, it will work.
  • Mateusz.MK
    7
    • December 9, 2019 at 12:40 PM
    It doesn't work. When I change extension from code to c4g and click open c4g file, I see this window.
  • massula
    205
    8
    1,439
    • December 9, 2019 at 12:49 PM
    You are right.
    I also tried to save the PDL with Save at PC button.
    I show the option to save as .c4g, but when we select it, it gives an error.
    I think the best option is try to edit the original .c4g
  • Mateusz.MK
    7
    • December 9, 2019 at 1:09 PM
    What do you mean the original file?
    File generated when I click save configuration on the TP is no ok ?
  • massula
    205
    8
    1,439
    • December 9, 2019 at 1:13 PM
    What is the extension of this file? If is .pdl, so its not ok.
    Maybe You will need to make a full backup of the robot, pick the .c4g file, edit it directly with WinC4G, and load it again on the controller.
  • Mateusz.MK
    7
    • December 9, 2019 at 1:50 PM
    • #11
    Hmm... No. I see file with extension c4g, I can open this file but when I modify code in this file and click save I see below window.
    I don't now how genereted c4g file with changed data in pdl and code file.
  • massula
    205
    8
    1,439
    • December 9, 2019 at 1:55 PM
    • #12
    What is the "Controller Version" parameter of You .c4g file.
    You can check this on the header of the file. 4th line.
    And this version is matching the library version setup on WinC4G?
    File > Properties > C4G Library Version.
