STRING REGISTER
  • Gunjan Trivedi
  • December 4, 2019 at 3:14 PM
  • Gunjan Trivedi
    36
    I know about SR[R] , R[] , AR[] . What is AR ? Can i write SR[]='ANY STRING' ?
  • Robo_Eng_13
    26
    432
    • December 4, 2019 at 3:47 PM
    1. AR is an Argument Register, which means it takes a value that you pass to it at declaration. Example, you can call a program SQUARE(2,3) and then SQUARE will read something along the lines of R[AR[1]] = AR[2] * AR[2], which will then place the value of 3 squared into register 2.
    2. Yes, you can use any string, within limits, in a string register. There will be some characters that i am sure you cannot make, and length limitations, but otherwise, a string is a string.
  • Muteki
    5
    27
    • December 4, 2019 at 4:29 PM
    Fun fact about the String Registers, you can add them together and use them to indirectly call programs or vision processes.
    SR[1] = 'ANY'
    SR[2] = ' STRING'
    SR[3] = SR[1] + SR[2]
    Now SR[3] = 'ANY STRING'
    I use them a lot for choosing vision processes when my system has several different parts it needs to check or move.
  • dha
    29
    397
    • December 5, 2019 at 7:08 AM
    Program:
    CALL MAKE_STR('ANY',' STRING')
    Program MAKE_STR:
    SR[1]=AR[1]+AR[2]
  • Gunjan Trivedi
    36
    • December 5, 2019 at 1:13 PM
    I can show a Register or String Register in a User Alarm?
  • SkyeFire
    1,060
    9,456
    • October 9, 2020 at 8:07 PM
    Regarding manipulating SRs in TP (not KAREL), the trick of calling a subroutine with strings as arguments seen in Post #4 above works for me, but the direct assignment shown in Post #3 doesn't. So,
    CALL MAKE_STR ('Any', 'String') works
    SR[1] = AR[1] + AR[2] inside MAKE_STR works
    SR[1] = SR[2] + SR[3] works
    SR[1] = 'Any string' will not build in RoboGuide (I'm writing .LS files and compiling them to .TP).
    Is there a trick to doing this, or am I just running into an inherent limitation of TP language?
  • Nation
    Typical Robot Error
    553
    1,935
    • October 9, 2020 at 9:40 PM
    Nope, setting a string directly is not allowed in TP. You have to call a 'setting' program like the make_str defined above.
    I think post #3 was just defining what was in the string registers.
Similar Threads
  • FANUC PROJECT: Data recording with background Karel program
    • Axillus
    • August 12, 2019 at 5:56 PM
    • Fanuc Robot Forum
  • Indirect access of system variables
    • Robot Programmer
    • June 10, 2019 at 10:00 PM
    • Fanuc Robot Forum
  • SR to a PLC
    • mathias39
    • June 3, 2019 at 1:14 PM
    • Fanuc Robot Forum
  • Numeric register
    • Akhil Mukundan
    • January 1, 2019 at 11:15 AM
    • Fanuc Robot Forum
  • :LS file or .TXT File to modify as .TP
    • ravitejagali
    • September 7, 2018 at 6:36 AM
    • Fanuc Robot Forum
  • String Registers
    • Fer_Rdz
    • October 25, 2016 at 2:56 PM
    • Fanuc Robot Forum
  • Setting string register from Karel
    • dha
    • February 16, 2016 at 11:36 AM
    • Fanuc Robot Forum
  • tp
  • AR
  • R
