How can i see how many UFrame are active in register ?
ACTIVE UFRAME
Gunjan Trivedi -
December 4, 2019 at 2:48 PM -
1. Only one and exactly one user frame is active at all times.
2. All user frames are valid and present at all times, even when not set or active. A User Frame that has not been set is the same as the World and User Frame Zero.
3. You should be able to use BG Logic and either regular commands or System Variables to store the value of the current active user frame into a register, if that is what you want.
Thanks a lot .
$MNUFRAMENUM[G] will show the active uframe. G being the group number.
