Sunrise.OS 1.16.1.9 / iiwa 14 R820 / flexFELLOW H900 Comfort
my iiwa is working fine and synchronization works (e.g. after chaning the safety configuration). I can't change anything in the station configuration though, because installing the project always fails. Afterwards I have to disconnect the robot from the power supply and the smartpad from the robot for a short time, then it reboots and everything works (unchanged).
There is a screenshot from the workbench attached. The smartpad says (in my translation) "Control installation has failed. Reason: Network connection to control was or is interrupted.". It also makes no difference if I plug my computer into the flexFELLOWs Ethernet Port or into the X66 of the cabinet directly.
I tried this with 2 different computers and different network cables. Did anyone experience this problem before?
Thanks for your help!
Best regards,
Mo
