Fanuc PLC,
  • Im completely new to FANUC plc system, I come to know I should use Fanuc Ladder III software:
    I got a backup with these files included:thinking_face:
    1)     ALL_PROGRAMM
    2)     CNCIDNUM
    3)     CNC-PARA
    4)     DCSPMC_IO_CO
    5)     DCSPMC_PARAM
    6)     DCSPMC_SEQUE
    7)     DCSPMC_TRACE
    :smiling_face_with_sunglasses:     MAINTINF
    9)     NETWORK.MEM
    10)  PMC_IO_CONFI
    11)  PMC_PARAM
    12)  PMC_SEQUENCE
    13)  PMC_TRACE_SE
    14)  PROFIMST.MEM
    15)  SV_SP_ID
    16)  SYS-CONF
    17)  ALL_MACRO
    I couldn’t able to open any of these files, should I need to convert into any other format (If so which file should I need to convert:question_mark::question_mark:?)
  • What are you trying to do?
    Your post doesn't really seem to ask a question, at least to me.
    Are you trying to view a PMC program that is already in a robot or are you trying to create a new program?
  • You need to open the Fanuc Ladder III software and setup the connection to the robot.
    Then you will be able to "upload" and view the program.
    Also if its a newer controller you can do it from the Teach Pendant.
  • Hi There!
    Sure you can Backup your files in readable format/text format. No need to worry about that, here is the tutorial guide please go through it and follow the steps. Let me know if you have any questions :smiling_face:
