I have an ArcMate 120 ilc that I'm using as a little material handler. I wasn't able to obtain core software as MH so I'm just using it as is. Is there a way to turn off the ARC-045 offline error since I no longer have the welder attached?
Fanuc Arc Mate 120
- Dan Ford
- Thread is Unresolved
Nation
Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum. -
You may be able to enter a controlled start and de-select the welder in the ArcTool Setup menu. I can't find anything that mentions if it is possible to undo the setup of a welding system.
