  4. ABB Robot Forum
Worldzone Rotate 45 Degrees
  • enagy
  • November 21, 2019 at 9:23 PM
  • enagy
    16
    My application has a robot rotated -45 degrees in relation to the cell. In order to get the WorldZones to line up, I changed the base frame Q1 to 0.92388 and Q4 to -0.38268.
    My understanding is that this will change the world co-ordinate system by 45 degrees so I can make the WorldZones line up with the cell.
    Is this the correct way to do this?
    Second, I'm having issues moving Axis 1 past 180 digress with the new world co-ordinate system. I've adjusted ROB1_1 upper joint bound to 3.927 (225 degrees), but it still gives an out of range error when I hit 180 degrees (I have restarted the controller). Is there another setting I need to change?
    SkyeFire
    1,061
    9,465
    • November 21, 2019 at 9:53 PM
    You should be able to use the PoseMult function to do this for you.
    For the Axis 1 error, you may need to use CONFJJOFF and CONFJ\ON before and after moves that cross certain quadrants. You probably want to break those moves up some, to minimize the amount of time/distance you spend with the Configuration Checking off.
  • enagy
    16
    • November 22, 2019 at 2:14 PM
    Quote from SkyeFire
    SkyeFire, thanks for the feedback, I'll give the CONFJ a try and see if that addresses that issue.
    In regards to the PoseMult, never heard of that one before and the manual is pretty vauge… Can you explain a little on how that works? I'm sort of getting the feeling that it will shift a position, are you suggesting possibly shifting the world zone?
    Thanks again!
    SkyeFire
    1,061
    9,465
    • November 22, 2019 at 7:28 PM
    I've used PoseMult on WorkObjects before. I'm not sure about WorldZones, but any RAPID variable that uses the standard POS and ROT sub-variables should be controllable using PoseMult.
    There's also a RAPID command I can't recall offhand that converts between QQQQ and RxRyRz. Using that in combination with PoseMult should allow you to rotate any "pose" object in undestandable angles, rather than trying to do Quaternion math by hand.
  • robotero
    14
    346
    • November 22, 2019 at 9:14 PM
    Quote from enagy
    Yes, is correct. Just update the orientation of the wobj0
  • SomeTekk
    17
    202
    • November 23, 2019 at 11:22 AM
    The function is:
    EulerZYX
    VAR num nAngleZ;
    VAR num nAngleY;
    VAR num nAngleX;
    VAR pose obMyObject;
    nAngleZ:= EulerZYX(\Z, obMyObject.rot);
    nAngleY:= EulerZYX(\Y, obMyObject.rot);
    nAngleX:= EulerZYX(\X, obMyObject.rot);
    Quote from SkyeFire
  • enagy
    16
    • December 3, 2019 at 4:12 PM
    Quote from robotero
    Thank you Rotoero,
    I'm still having an issue of jogging the robot Axis 1 past the 180 degree point though when I rotate the wobj0. Keeping in mind, I'm only doing this in Robot Studio at the moment, I haven't tried it on the actual robot yet (holiday installation).
    Lemster68
    301
    2,491
    Blog Articles
    7
    • December 13, 2019 at 3:50 PM
    Unless your robot has the axis one extended range option, you should not be able to go past 180 anyway, you will hit a hard stop. There are two parameters, upper or lower joint bound, and upper or lower joint max bound.
