First time poster, I made sure to use the search function. I couldn't find a solution to this problem.
The camera i'm using shuts off every 3 cycles... like clockwork... I shut down the robot and the problem goes away. I aimed the camera to some light fixture so That I could tell the camera was on without having to turn on the red light ( a little lazy, but I wanted to know right away that the camera was working when i turned it on).
Anyone have had issues with their camera shutting off? We thought it was a grounding problem, but we grounded the robot and we thought we had solved it... but the problem came back and we're all scratching our heads.
Camera shutting off
Molusk -
November 13, 2019 at 11:50 PM -
Are there any error codes? Could be a bad or loose cable.
I received a couple of errors that same day. SRVO-003 , SRV-378, HOST224 DHCP : No Response from server.
Could improper grounding cause this?
I was having issues with loose cables, like blurry and crt tv issues where the image is rolling down continuously. I unkinked the wire and everything straightened up.
I would try a brand new cable.
