Hello ,
I have two teach pendants for FANUC RJ2 controller. one of those works fine without any problem but the other gives fence open error. how can i solve this problem? is it required any jumper or something like that?
thanks for any help
Hello ,
thanks for any help
Make sure the teach pendant is compatible. If it is, it's usually an issue with the Enable switch.
The control cable runs smoothly on one of the control panels and gives error on the other, as I understand it. Please check the latch section of the controller that caused the latch error with the meter. If the latch section is running smoothly; when you follow the cable from the latch section, check the "smd diode - possibly M7 coded" elements that pass the signal from the latch on the electronic card again with the measuring instrument. You need to see separate diodes for each latch of the controller. The electronics guy can control them. If the diodes are solid when you follow the circuit will still be SMD 16 or 24 legged door integrated you may need to change them.
