ArcTech Basic weave plane
  • Anton D.
  • November 13, 2019 at 9:46 AM
  • Anton D.
    Hey, everybody! I use ArcTech Basic option for weave. Tell me, where change angle between Ztts and Ytts. Initially, it is equal to zero and at a set point of 0 degrees weave correspond to 3rd picture, but should correspond to 1st picture.
    panic mode
    1,262
    13,027
    • November 13, 2019 at 5:39 PM
    The TTS is a coordinate system that moves along the path with the robot.... so change to tool orientation when teaching path.
  • Anton D.
    • November 13, 2019 at 5:50 PM
    I'm sorry, but can you elaborate on what you mean by teaching path
    panic mode
    1,262
    13,027
    • November 13, 2019 at 6:46 PM
    it is a process of programming points. it means inserting motions instructions into a robot program.
    if already programmed step through program, change tool orientation and touchup points you want changed.
  • Anton D.
    • November 14, 2019 at 9:47 AM
    Quote from panic mode
    Yes this is true. Task that I decide a little different.
    Initial conditions:
    - tool orientation is defined;
    - Frequency = 2Hz; Amplitude = 2 mm; Angle = 90 degrees; Pattern = Triangle; Length = 100 mm;
    Actions:
    - Moving along the seam LIN team. Ok. Weave correspond to the 1st picture.
    - Rotate the tool 15 degrees along the Ztts axis. Boom. Weave correspond to 3rd picture.
    I think it has something to do with 90-degree angles...
  • Anton D.
    • December 2, 2019 at 1:47 PM
    Apparently panic_mode was right.... This effect appears only at tool direction Z. Helped change to a tool direction +X and change configuration tool
  • ArcTech
