I can not copy a directory and its contents in the KUKA KRC4 Explorer (ie copy from or to USB key). I Can copy files with Edit/copy, but for a directory Edit/copy is not available.
Does anybody know how to do this ?
BR
BR
I think I was able to make this work several years ago, by diving into the KRCConfigurator program and messing around. It was, IIRC, under the Methods tab.
But that was several KSS versions ago, and I've never seen a detailed manual for that part of KRCConfigurator, so you'd probably have to trial-and-error it. Make sure to take backups before you start.
I have an answer from Kuka : it is impossible.
The solution is to do it from windows explorer (use "reduce HMI" function)
BR
