Fanuc Dinamic override of robot speed
  • Hello to everyone and thank you in advance for your help.
    I have a Fanuc R-30iB Plus controller and i'm looking for a way to limit online the speed of the robot's movimentation while a program is running in auto.
    More specific i have a vision system that check if there is any operator in a defined operating area of the robot and calculated the distance between them, i want to slow down the robot gradually in function of it.
    I have found something using the DCS (Dual check safety) like speed check function and the slowdown zones, but i dont know if it is possible control it using an external device or using it for my purpose.
  • You can use Override Select function(Menu -> Setup -> Override Select) , set up a DI that will be turned on if the person is present in secured area, and if that DI turns on, the robot speed will be modified.
  • Major question: is this for safety purposes (meaning, has to be done to meet or exceed a risk assessment) or operational purposes (robot will meet RIA standards without this feature, but will operate better with it)?
    If it's for safety, your options are limited to safety-rated options such as DCS; if it's operational, then you can use other options (and/or DCS) to fulfill the task.
    Edit: This seems to be a safety function, unless I am incorrect in the implementation here. If it's a safety function, be VERY careful on how you complete this task. Vision systems, Group Inputs, Digital I/O signals, TP programs, and even most System Variables are NOT considered safety rated.
    Quote
    After implementing any solution, I suggest performing a risk assessment on the whole system to make sure you're still safe.
  • Thank you for all of your answer.
    Stare284 and amotov, i will try both of your solution.
    To domo_arigato:
    Quote
    yes it is, but is for research only.
    I will perform a test in a controlled environment so i can avoid to use the DCS, but your analysis is very accurate and
    Quote
    thank you for your advice, i will perform a risk assessment on the whole system.
