Our KRC2 controller was stuck with an error message for External Estop Pressed which couldnt seem to clear. On checking the wiring for the estop and the connectors behind the button all seemed fine. It was only on manipulating some of the wiring from the estop to the safety relay that occasionally the error would go away allowing the robot to be jogged. On disconnecting the wiring to the safety relay and reattaching, making sure all was firmly in place the relay itself seemed to be more stable in terms of faults however the KCP is now showing errors of 'E-Stops pressed', Safety Circuit for drives not ready' and 'unknown operation mode'.
The wiring to the relay is as it was, took care to make sure wiring was returned to original, it just seems that something along the way has caused an issue between the safety relay and the controller.
Any ideas would be welcome! The old trick of a re-boot doesnt do anything to the errors.
Many Thanks
