We have a fixed camera taking a picture over a shaker table. The camera has 2 existing vision sequences and we’re trying to add a third, but, the original programmer isn’t available. I have the vision system working, finding instances of the part we’re picking, and displaying the location in the vision window, but the robot doesn’t get the coordinates. If I reference one of the other existing vision sequences it works every time, so, I’m guessing I need to tell my new sequence to output the data somehow?
The code is simply:
SET loc.pick = VLOCATION($sv.client_ip, g.fd.seq.stuck, 4, 1, 1311, 1) ; Sets the robot target to the matched instance from the vision system
SET loc.pick = loc.pick:pick.offset ; Sets the height offset to prevent crashing
After this runs, loc.pick = 0.000 0.000 0.000 0.000 0.000 0.000
But, the old code works, and the only thing that’s different is highlighted below:
SET loc.pick = VLOCATION($sv.client_ip, g.fd.seq.pick, 4, 1, 1311, 1) ; Sets the robot target to the matched instance from the vision system
Both sequences are constructed the same as Camera, Blob, Locator, Gripper clearance, final results.
I'm not sure if it's relevant or not, but, I noticed this morning that "loc.pick" is NOT in the V+ User Variables/Locations module, but is initialized at startup with the note "LOADS APPLICATION-SPECIFIC ROBOT LOCATIONS FROM FILE."
Thanks in advance!
