  4. Kawasaki Robot Forum
Error when passing arguments to AS subroutine using Duaro 2 robot
  • dohlfhauldhagen
  • October 10, 2019 at 4:30 PM
  • dohlfhauldhagen
    7
    59
    Hey all. I'm working with a Duaro 2 robot.
    I am trying to pass an argument to a program via a subroutine call from an AS program. The AS program I am calling looks like this:
    .PROGRAM PlaceWarmTray(.Arg1)
    <code here>
    .END
    I try to call it from my main program like this:
    CALL PlaceWarmTray(1)
    Every time I try to run the program, I get “Error Code 2018 Check the argument settings in macro pg” on the tablet. The confusing thing is, when I call the program from a tablet program and enter in an argument that way, it works just fine. It just doesn’t work when the program is called from an AS program. Has anyone run into this before?
    Thanks!
  • kwakisaki
    694
    4,770
    • October 10, 2019 at 4:53 PM
    In program PlaceWarmTray, are you referencing .arg1 at all?
  • dohlfhauldhagen
    7
    59
    • October 10, 2019 at 5:58 PM
    Quote from kwakisaki
    Yes. Here is the full program:
  • kwakisaki
    694
    4,770
    • October 10, 2019 at 6:37 PM
    Your syntax maybe incorrect here.
    I've never come across the ELSEIF instruction as a valid syntax in any Kawasaki Robot.
    The Duaro may have some additional AS instruction to incorporate ELSEIF, but looking the AS Manual for Duaro, it doesn't appear to be there.
    The equivalent is CASE OF statement:
    CASE .arg1 OF
    VALUE 0:
    VALUE 1:
    VALUE 2:
    ANY :
    END
    Try that and see if it makes any difference.
    *** With the ANY instruction make sure to include a space after and before the colon, otherwise it's treated as a label ***
  • Alexandru
    49
    407
    • October 10, 2019 at 9:19 PM
    if you want to stop the robot at ANY condition you can write something like this:
    ANY :
    PRINT "Invalid value"
    PAUSE
    END
    It will pause the cycle on from the robot and the robot will stop.
  • Motouser
    39
    288
    • October 11, 2019 at 12:40 PM
    YASKAWA EMPIRE strikes back:grinning_squinting_face::grinning_squinting_face::grinning_squinting_face:.
    This is a big difference between kawa and yaska: in AS language the if and else is a little poor, otherwise in Yaskawa(and even in STAUBLI) the elseif command is like the case of a SWITCH..CASE instruction.
  • kwakisaki
    694
    4,770
    • October 11, 2019 at 4:40 PM
    For sure, many OEM's use different IF syntax (I'm encountering something similar with Fanuc at the moment) but it is what it is.
    What is puzzling me is the error.
    It is not a standard Kawasaki error I have come across and has no reference in the Kawasaki Troubleshooting Manual.
    If it was a file loaded in via KRTerm (PC to Controller) you would receive a different error.
    I think files transferred from tablet to controller use internal macro's and I think this error is a tablet generated error as it cannot compile it.
    I have tried to locate this error in the Duaro docs I have, but haven't found anything.
    Something to feedback to Kawasaki I think if indeed this is down to incorrect syntax.
  • kwakisaki
    694
    4,770
    • October 11, 2019 at 5:12 PM
    Another thing, I have come across in the documents I have is the attached release notes relating to the addition of the CALL program function.
    If refers to the CALL program specifically and relates the argument towards a location only and not a real variable.
    Not being completely conversant with Duraro, I wonder whether this also has a bearing on this problem to.
    Be worthwhile checking this with Kawasaki and also the software version etc.
    Files
    duAro_Release Notes_007_20161103.pdf 350.2 kB – 13 Downloads
