I set up a speed check and had override set to 0% but the robot still moves at very fine. I'm curious if you can get the robot to actually stop moving but keep running
Speed check
- ASIJordan
You can disable group motion under the test menu. The robot will run as if it is moving, but no real motion will happen.
You can also enable 0% speed override in system config, and dropping the robot to 0% speed will stop it. You have to be on V9 or higher for this though.
