KR150L130 to KR150
  • javaman
  • October 10, 2019 at 10:56 AM
  • javaman
    5
    318
    Can a KR150L130 modified to be a KR150?
    Is the extension of extra 200mm removable?
    So the robot to have less envelop but more payload?
  • Leon
    35
    5
    476
    • October 10, 2019 at 12:19 PM
    Yes it is possible, but its not as easy as you might think. You have to take the wrist of, remove axles for the wrist (a4 tot a6). remove the extension that was between the wrist and the arm. Replace axles with standard short version an mount everything back together. Not sure if there where more changes than just the axles, it has been a few years since i discussed this with a kuka engineer.
    After assembly change mada and remaster and you should be good to go.
  • javaman
    5
    318
    • October 11, 2019 at 10:44 AM
    rdc must changed to identify as kr150 or not ?
  • Leon
    35
    5
    476
    • October 11, 2019 at 1:26 PM
    No, you can keep the same RDC, you only have to change mada in the KRC en remaster.
  • Fubini
    283
    1,905
    • October 11, 2019 at 3:44 PM
    Just in case: You will also need a different pid-file in case of an absolute accuracy robot.
    Fubini
Similar Threads
  • KR150L130 & VKRC2
    • javaman
    • July 22, 2019 at 11:26 PM
    • KUKA Robot Forum
