TC_ONLINE INSTRUCCION
  • All
    How you doing?,
    I´m looking for info about TC_Online instrucción; I´ve been used this instruccion before but I´d like get the real info from Fanuc Manual I had try search in manual but I didn´t success
    Regards!
    Tlalóc<br />Always take it easy!!!!!
  • HawkME,
    I´d like to know If can I interrupt a movement when PLC sends a DI?; If robot doesn´t catch that signal I want to stop it as an usually works TC_ONLINE.
    I tried to do it with skip instruction but the robot pauses for a moment and it keeping running, robot never catch the signal to stop.
    I did this
    94: !~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ;
    95: !Conveyor_1_Perch ;
    96: LBL[1] ;
    97: R[1:R1 DESTINATION]=10144.7 ;
    98: WAIT 1.00(sec) ;
    99: WAIT DI[8:OK TO MOVE]=ON ;
    100: ;
    101: ;
    102: SKIP CONDITION DI[9:Transfer Home]=ON ;
    103: ;
    104:L P[10] 3000mm/sec CNT25 Skip,LBL[810] ;
    105: ;
    106: JMP LBL[700] ;
    107: ;
    108: LBL[810] ;
    109: CALL ROBOT_HOME ;
    110: ;
    111: WAIT DI[8:OK TO MOVE]=ON TIMEOUT,LBL[15] ;
    112: ;
    113: LBL[700] ;
    114: ;
    115: !Vision Perch ;
    116: IF (DI[1:PICK A] AND R[16:STATIC PICK A]<9),JMP LBL[33] ;
    117: !OR ;
    118: IF (DI[2:PICK B] AND R[18:STATIC PICK B]<9),JMP LBL[33] ;
    119: ;
    120:J P[11] 85% FINE ;
    but the robot is going jumping directly to LBL[700] and never go home the robot just stop for 0.5 sec and keeping running never CALL Robot_home.(T2 mode)
    If I got simulate DI9 signal that robot CALL Robot_home (T1 Mode)
    I just want interrup a movement with a DI and CALL Robot_home (program with movements)
    I don´t want to use a Kind of searching rutine with several positions asking for that DI.
    regards!
    Edited once, last by WEBER ().
  • You have Jmp lbl 700 right after your skip, so that's what it will do. When the skip condition is true it interrupts motion and goes to the next line. Lbl 810 will only be reached if the DI never comes on.
