Hello everybody,
I have to do some long modification in several PNS of several robots. It will be hard to do that using the TP, and I am having some problems with Roboguide...
So, given these modifications don't include new paths, I wonder if it is possible to modify the PNS with the NotePad++ or a similar software. And if it is possible, how is the right way to import/export it?
Thank you very much.
Notepad
ctor -
October 3, 2019 at 3:00 AM -
To answer your question, YES. You can modify the .ls file of the program offline. However, to load the code back into the robot, you need 1 of 2 things.
1. If your robot has the ASCII upload option, you can load the .ls file directly to your robot.
2. If your robot does not have the ASCII upload option, you must compile your code and load the .tp file to the robot.
If you do decide to go with notepad++, here are some links to some syntax highlighting config files that will make programming easier.
