Good afternoon , I have a robot kuka kr60-3 releasing oil on axis 2 from the part of the gearbox and fron below the servo motor.
is there procedure to disassemble and replace the seals and retainers ?
there are only 2 Shaft seals on axis 2, if the oil is leaking anywhere else you in for a hole new gearbox
00-121-102 Shaft seal 45x68x9F
00-125-321 Shaft seal 52x70x9F
