Conveyor Tracking issue with CNV2
  • Hello all,
    First of all i am quite new to the ABB robots so don't know all the different features of the system.
    I am setting up a system using the documentation which has 2 DSQC377B boards.
    I have successfully setup CNV1 and have the robot tracking perfectly. Great!
    However, the second conveyor CNV2 position is not correct. This is the case with the physical encoder or simulating. I did swap the components to confirm there was no hardware problem with the encoder, cable etc. So I am somewhat confident it isnt a wiring issue.
    What i see when i run the conveyor is a value in the c2Position variable proportional to the speed of the conveyor. Wierd right? For instance if I run slow i get 0.1. if I run faster i get 0.5 etc. When I stop the position returns to 0.
    I have checked all the values that i can find in the config and IO signals and they are all the same (Except for the devicenet address of course).
    Anything else i should be checking to try and diagnose this?
    Any assistance is appreciated and thanks in advance.
  • Place your Ad here!
  • No I have both conveyors activated on startup.
    I think I found my problem and realised that the conveyor position in the jogging windows does not count until an object has passed the trigger sensor.
    Does this seem correct?
