I wrote an open-source command-line tool called fexcel a while ago that reads an Excel spreadsheet and then populates the comments/labels for things like registers, position registers, string registers, user alarms, I/O, etc.
You basically tell fexcel where your data is located, how the columns are laid out and a list of robot IP addresses, and it will go and do everything for you... probably in less than a second. (Probably overkill, but it works concurrently. i.e. it takes about the same time to label one robot as it does to label 20 robots)
Usage:
Make sure KAREL is unlocked under Setup > Host Comm > HTTP.
fexcel [options] filename host(s)...
> ./fexcel -sheet Data -numregs A2 -posregs D2 -dins IO:A2 spreadsheet.xlsx 127.0.0.101 127.0.0.102
You can read more about it here or at the project's GitHub repository. Download the latest release here.
