Error Conveyor Tech KUKA
  • Hello, I'm trying to configure a KRC4 robot to use TP Conveyor Tech but when I make this configuration in Workvisual appear an error:
    The plug in ConveyorComponent caused an error during code generation!
    And, it doesn't appear more information related with this problem. I have done the following steps:
    In the last step, It's when appear the error message. Conveyor tech versión that I'm using is 6.0 . I'm working in workvisual 5.0.
  • please read pinned topic READ FIRST... you should mention exact versions
    your project fails to compile so you are doing something wrong.
    are you sure that WoV is correctly installed and configured?
    are you sure that you integrated correct KOP versions?
    are you sure option is installed on KRC4 before you transferred project from KRC4 to your WoV?
    are you sure you followed steps correctly about conveyor tech configuration?
    did you try to restart WoV?
