Advertising
How to attatch a laser to a dx100 and create a job that turns it on/aff
  • Hi,
    I need to attach a laser to a motoman mpl800 dx100.
    The program is created with robodk software and will look something like this:
    MOVJ C00000 VJ=100.0
    MOVL C00001 V=150.0
    CALL JOB:M3
    MOVL C00002 V=150.0
    MOVL C00003 V=4.00
    MOVL C00004 V=4.00
    MOVL C00005 V=4.00
    MOVL C00006 V=150.0
    CALL JOB:M9
    MOVL C00007 V=150.0
    CALL JOB:M3
    The Call JOB:M3 needs to turn the laser on and the CALL JOB:M9 needs to turn it off.
    The laser has a output wire with 5volt. The relay should then allow these 5 volts to go back to the laser through the input wire which will get it starting.
    the cn307 connector looks like this
    In which connector should the input wire and output wire go in the cn307? and is it correct to use the cn307?
    So now I need to create the jobs M3 and M9 and somehow get them to turn the laser on/off.
    From reading around the forum I guess I need a DOUT command but I don't know how the job should look or how I get it to point to right connector?
    Any help will be highly appriciated as this is very new to me.
  • I got it working by making two programs- M3 and M9:
    NOP
    DOUT OT#(12) ON
    END
    NOP
    DOUT OT#(12) OFF
    END
    The input wire we just attached to the Blue wire that goes in all the A connectors. The output wire we connected to the B11.
    When the main program is runand it comes to the job M3 is called the output wire give out 5 volt which triggers the laser to start
  • If you are talking about a laser which is a sensor or something, ok. BUT, if you are talking about high power laser for welding or cutting, you should have it in your CIO ladder so that if the robot stops because of a fault or ANY interruption, including e-stop it needs to turn OFF. At the minimum, have a safety circuit that will interrupt your output power, thereby turning the laser off.
  • Its a 80W laser so its not high power but safety is always a concern.
    I don't know anything about CIO ladder so I will have to look into that. I found some manuals from motoman but if you can give some pointers as how to go about setting up the CIO ladder that would help alot.
  • An 80 watt laser is not low power. A low power laser has a class two rating or lower.
    I never said it was low power. I said it was not a high power laser as I know lasers for steel are 4000W+. That being said I have read about laser classes and a 80W laser is in one of the highest classes.
  • Hello,
    I work with ladder programm. But you really schould know what you do in ladder.
    I'd prefer a course from yaskawa before you work with ladder programm.
    If you know the basics I can help you with ladder programm.
    Generally in Ladder you can handle whole In- and Outputs of robot, also special signals like Servo on, Running, or in which cube the Robot is. It is the internal SPS of the robot.
    For your project, you have to set Registers or Outputs to tell the Ladder programm switch on/off Laser,
    but if robot not running or safety-fence open always switch off the Laser.
    Also Ladder Editor on the controller is a paid option. Do you have it?
  • I never said it was low power. I said it was not a high power laser as I know lasers for steel are 4000W+. That being said I have read about laser classes and a 80W laser is in one of the highest classes.
    For visible-light lasers, Class 4 lasers' have an output power 500 milliwatts and above. There is no upper limit for Class 4 -- this is the most hazardous laser classification.
    It's kinda like being shot in the temple with a .22 versus a 50 cal, both will kill you dead. I've met people who have lost part of their vision to a class 3 laser; lasers are not to be underestimated, even the reflections off of matte surfaces can be dangerous.
  • Here is what I can advise you regarding conditions that you must consider: Motors are ON, NOT faulted, program IS running, NOT E-stop or Auto Stop (of course motors would be off if this is the case) and probably use a pseudo output in your job which ties into all these other conditions to turn on the real output to turn on the laser. Like how in ABB we would set up our cross connections.
  • Why do you want the on and off instructions in separate Jobs? I think its more visual to have the instruction directly in the program.
    MOVL
    MOVL
    DOUT OT 12 ON Laser ON
    MOVL
    MOVL
    DOUT OT 12 OFF Laser OFF
    Or you could use a while command
    Might be wrong here
    While D001 =1 AND (IN for servo on) = ON
    DOUT OT12 ON Laser ON
    MOVL
    SET D001 1 (laser should turn on)
    MOVL
    MOVL
    MOVL
    SET D001 0 (laser should turn off)
    MOVL
    MOVL
    MOVL
    MOVL
    MOVL
    END WHILE (disables the function)
    It could be worth a try instead of messing with the Ladder
