Advertising
Programming question
  • Hi guys,
    I have a simple question today, I've been working for a company that use a lot of old yaskawa(NX100, not so old indeed) and a couple of days ago I've found a piece of code like this:
    MOVL C00000 V=1000.0
    GETS LPX000 $PX0001
    'do some maths
    MOVL LP000 V=200.0 PL=0
    How much is safe/right doing this?
    Getting a position, after moving very fast to a position: it's like do it on the fly?
    Also I would use a Pxxx variable not a Cxxx?
    What is your opinion?
  • I just tested it on a DX200 and it turns out, it doesn't do it on the fly - you get the exact position.
    If the position doesn't have to include shifts or no shifts are active turing the move, it's also possible to use $PX004 in GETS instruction - that will get the position of the previous MOVx instruction without shift data.
    In my opinion using Pxxx vs Cxxx is a matter of preference and what the programmer is after. And also which works better with the current task.
  • If the results of the code are repeatable and with desired results, then it is fine. Does the robot achieve that speed? I have programmed quite a few older cells where I had the speed maxed out. The robot never even got close to that speed due to the distance between positions and the accel / decel factors.
    Using servo command positions vs. position variables is preference and depends on the application. They each have their advantages and disadvantages.
    Alcohol: The cause and solution to all life's problems
  • it's also possible to use $PX004 in GETS instruction
    $PX004 is in pulse. He is using $PX001 which is XYZ Base Frame. A programmer may not know that they would have to use the CNVRT instruction. $PX007 is XYZ Base Frame minus the shift amount.
