  4. ABB Robot Forum
ABB IRB 6700 GuardStop;Motors are not turning on in Manual Mode
  • robomaniac
  • September 12, 2019 at 3:03 AM
  • robomaniac
    25
    Hello Everyone,
    We have installed one ABB IRB 6700 robot for pick and place application.The Auto stop of the Robot controller is wired with the Cell entry Gate.So,Auto stop signal in robot controller drops when the gate is open and it stops the auto cycle of the robot.But Currently,when robot is in manual we are not be able to turn on the motors and the controller stays in the guardstop state.
    Can anyone please share any insight in this.Let me know if you need any additional details
    Any help will be highly appreciated.
    Thank you
    :guru:
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • September 12, 2019 at 1:38 PM
    So you need to ensure that the GS, ES and SS runchains are closed (lights ON).
  • robomaniac
    25
    • September 12, 2019 at 4:54 PM
    Thank You,
    So when I open the door only GS,ES,and SS lights are stay On only AS Lights are off.
  • SomeTekk
    17
    202
    • September 12, 2019 at 5:43 PM
    Delete all the event logs and try to enable the motors. Check the event log in its entirety for further clues, such as motors on inhibited by a motors off system input, etc.
  • robomaniac
    25
    • September 12, 2019 at 8:34 PM
    Quote from SomeTekk
    We did that and we made sure that this is not the case.For curiosity is it possible that this is caused by safemove Supervision zone?
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • September 12, 2019 at 9:33 PM
    So you have safemove, it should still be telling you why it is not allowing motors on. Have you tried another pendant? Maybe the enabling device is faulty.
  • robomaniac
    25
    • September 13, 2019 at 7:50 PM
    Quote from Lemster68
    Thank you again,
    yes,we have safemove setup but I made sure that it's not happening because of the safemove.The enabling device works perfectly when the gate is closed(i.e AutoStop OK) .The motors are turning on and we can jog the robot.But as soon as we open the door motor goes off and its not even giving us any fault on TP Screen
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • September 13, 2019 at 8:19 PM
    Autostop should never stop the robot in teach, are you sure that is the only part of the runchain that opens? Are ES, GS and SS BOTH light on for each?
  • roulv
    104
    • September 13, 2019 at 9:48 PM
    Check if something else is wired in panel board. There is one contact for external enable device. If it's open you get no errors, but motor will not turn on.
  • SomeTekk
    17
    202
    • September 15, 2019 at 12:45 AM
    Do you have terminal strips with bridge connectors in their correct places to complete ALL the stop circuits as a reference point?
    If so the Panel Board may be suspect.
  • robomaniac
    25
    • September 16, 2019 at 2:05 PM
    • #11
    Yes When we open up the door in manual mode.It only opens up AS1,AS2.All the other lights of GS,ES and SS are ON
  • robomaniac
    25
    • September 16, 2019 at 2:06 PM
    • #12
    Quote from roulv
    Thank you for the input.If you have more information about the board number and pin number can you share that with me?
    Thank you
  • robomaniac
    25
    • September 16, 2019 at 2:07 PM
    • #13
    Quote from SomeTekk
    I was thinking to do that.Probably I will do that and share results here.
    Thank you
  • robomaniac
    25
    • September 16, 2019 at 8:06 PM
    • #14
    Thank you everyone for your help.
    the real issue was faulty Auto-Teach Switch.One of the contacts on the switch was faulty.And it didn't recognizing that the robot is on the manual mode.We changed the contacts and it started working.
    Thank you again
  • IRB6700
  • Guardstop
  • MotorsOFF
  • Autostop
