  4. ABB Robot Forum
S4C+ backup restoring / too large file
  • schelle
  • September 10, 2019 at 11:17 AM
  • schelle
    32
    I have an IRB1400 M2002 with S4C+ controller.
    Previous owner provide me backup file, but it takes 2.7MB disk space. It is impossible to be restored using floppy drive because floppy disk capacity is 1.44MB and file can not be splitted.
    I tried to connect USB emulator on floppy bus, but robot didn't recognized connected device. I try also with another one USB emulator, but result was same - when I try restore, robot offer hard disk and option UNIT to change device; after choosing UNIT, robot tried to connect with external device but with no succeed. It works only if I connect floppy dis instead USB emulator. I tried also to choose some address on emulator, but with no difference.
    Considering that someone before took backup of 2.7MB for sure there is the way how to restore it now. Could someone advise me what to do to complete my task as well?
    BR/
    Schelle
  • simont14
    45
    • September 10, 2019 at 11:46 AM
    did you try to change the format of your usb ? I mean, if you are on ntfs, try the fat32 format
  • schelle
    32
    • September 10, 2019 at 11:57 AM
    I'll try to do that, but I'm doubt because robot didn't achieved to recognize external device itself if it isn't floppy.
  • robopal
    19
    • September 10, 2019 at 12:12 PM
    Have you tried to do this with FTP? Should not be a problem with S4C+.
  • schelle
    32
    • September 10, 2019 at 12:24 PM
    FTP sounds great, but how?
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • September 10, 2019 at 1:49 PM
    Get filezilla.
  • Skooter
    169
    2,026
    • September 11, 2019 at 5:43 AM
    Quote from Lemster68
    Get filezilla.
    You will also need a crossover cable if connecting directly between a laptop and the ABB service port.
    Search the forum and you will find lots of info regarding connecting to the S4C+ service port.
  • schelle
    32
    • September 12, 2019 at 3:25 PM
    If I already sent new created system to S4C+ controller thru same cable, is that means that cable is useful for FTP as well?
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • September 12, 2019 at 3:49 PM
    Yes
Similar Threads
  • archive.zip restore fail
    • strecht
    • July 16, 2018 at 12:04 PM
    • KUKA Robot Forum
  • HDD Filling up with .tmp files and Load Time is getting Longer
    • enagy
    • April 21, 2018 at 7:50 PM
    • ABB Robot Forum
  • floppy drive
  • flash stick
  • abb s4c+
  • backup file
