  4. Stäubli & Bosch Robot Forum
Linking a Staubli robot position to an output
  • JamborT
  • September 5, 2019 at 3:17 PM
  • JamborT
    Hello All,
    I am currently working with a TX200 robot and a CS8C HP controller. I was wondering if there is a way to link a position to an EtherCat output. For example if i teach a position named home, and I want to send out a signal to my PLC when the robot is in that position, how would I do that? Kuka has a standard InHome signal, I'm trying to make something similar. Any ideas?
    Thanks!
  • TygerDawg
    187
    • September 6, 2019 at 5:06 AM
    I don't recall that there is any "standard signal" for this or other functions of this nature.
    I would create and execute a secondary task that would constantly monitor if the TCP is within a tolerance to the desired location. Then enable an output when it is.
    Something similar to this snippet that I found in my archives:
        //  CHECK ZONES
        //here() returns the current position of tToolAdj tool in world frame.
        l_pHereCart=here(tToolAdj,world)
        l_trHere=l_pHereCart.trsf
        // You can uncomment this selections if you want to monitor
        // joint position.
        //Return the current arm joint position.
        //l_jHereRevol=herej()
        //Test zones example :
        //if l_trHere.x<750 or (l_trHere.x<350 and l_jHereRevol.j1>-30)
        //ZONE 1
        if l_trHere.x>300 and l_trHere.y<-200
          //Robot outside Zone 1
          //doInZone1=false
        else
          //doInZone1=true
        endIf
    TygerDawg
    Blue Technik
    http://www.bluetechnik.com
  • output
  • position
