Turn on DO if any IOis simulated
  • Under MENU>SYSTEM>CONFIG there is an option to turn on a DO if either an Input or Output is simulated. Looks simple enough to configure but I have not done it on ours yet. I do believe you need to cycle power after you set the DO you want on the config screen. This reminds me though, I wanted to do this on our robots at one time and forgot until I saw this post. I think I know what i'm doing tomorrow!
    "I could tell that my parents hated me. My bath toys were a toaster and a radio."
  • As long as they don't sim the output that tells you that bits are simulated. :winking_face:
    Another option is to setup the robot to force all sim bits off upon cycle start.
    MENU->SETUP->PROG SELECT-> Simulated I/O ->Detail, Check when run and resume, Force condition.
    I plan on using a very high numbered DO for mine just to ensure they don't do this haha.
